08 Sep 2025 01:48 PM
hello,
I’m new to Dynatrace and I tried to configure disk monitoring, but I’m facing an issue:
Disk on environment level, 15%
I set up an environment-wide disk usage threshold of 15%.
Disk edge on host level, 13%
On a specific host, I separately configured a disk edge threshold of 13%.
Why I receive alert from both? Is it okay that alerts are coming from both settings?
08 Sep 2025 02:14 PM
Disk Edge is an improvement to before one. If OneAgents are sufficient updated, you can use only Disk Edge, since it has more flexibility.
Best regards
