Docker containers - monitoring & alerting?
scott_brenner
Newcomer
  • Is it possible to create alerts for Docker containers, such as creating an alert when a container crashes/restarts?
  • Is it possible to create dashboard tiles with the container metrics (CPU, memory, etc.) that are visible when examining containers in the UI? I'd also like to create alerts for these metrics if possible.
3 REPLIES 3
francois_vangra
Inactive
Hi @Scott B.,
It's not possible at the moment. The workaround is to either build a plugin that pulls data from docker stats, or just use the API to push events once you've analyzed the docker stats from some location.
I'm currently working on an agent based plugin for this but it seems like there might be easier ways to get the job done. Will let you know once I find a viable sulution.
bartosz_gatz
Dynatrace Advisor
Dynatrace Advisor
Hi.
We are currently in the process of discussing the plans for investments into Docker monitoring including, but not limited to, cpu and memory utilization and alerts. Please stay tuned for more updates in several weeks.
There is an associated thread about similar topics here: https://answers.dynatrace.com/spaces/482/dynatrace-open-qa/questions/181813/how-to-get-alerts-on-cpu-utilization-of-container.html
Bartek.
Hi Bartosz,
Will the new capability also support capturing of Docker Events - See https://docs.docker.com/engine/reference/commandline/events/#object-types?
