Dynatrace CPU problem details - difference in overview
spostma
Inactive
Looking at a Problem CPU Saturation i notified the big difference in CPU statistics.
This systems contains 4 logical CPU cores, it seems in this graph that Sync_Gateway is using 2 out of 4 cores, causing the CPU alert. (over 90%)
which in total brings the Total CPU to 47% correct?
Is there a more easy way to further look into this issue?
ChadTurner
Guru
thats very interesting, are you still having this problem? what version of the oneagent were you running? Have you oneagent? did the update fix your problem?
-Chad
