Entity Selector for Davis Anomaly Detection
william_cher
Participant
Is there a way to link the problem event raise from Davis Anomaly Detection with an entityId? For example, adding entityId into Event Properties.
Peter_Youssef
Leader
Hello @william_cher
Regarding the highlighted concern PFA helpful resources:
Kindly Note:
  • The entity ID is an auto generated and assigned value by Dynatrace, it can't be updated.
  • Through the alerting profiles even when you customize the body of the problem notification contents, the following entity parameters are available "{NamesOfImpactedEntities}, {ImpactedEntity}, {ImpactedEntityNames}, {ImpactedEntities} "
  • The available IDs through the alerting profiles: "{PID} , {ProblemID}", so it doesn't have an entity ID to be correlated.
Tip:
  • Feel free to raise a product idea having the entity ID correlated with Davis AI outcomes "Events, Problems, ...etc"
The latest updates to the Dynatrace API have a strong focus on liberating access to data-driven problem solving and making them accessible by everyone - not just developers. There have been major improvements driven by our community that allow everyone to get easy answers to everyday questions ...
GosiaMurawska
Community Team
Community Team
Hi @william_cher, did you manage to solve your issue? I'm sure the rest of the Community wants to know the solution 🙂
