05 Feb 2020 12:10 PM
Need to understand what below statement means and how calculation is done in problem "applications: User action duration degradation".
The current response time (1.12 s) exceeds the auto-detected baseline (219 ms) by 412 %
Attaching a screen grab.
AK
10 Feb 2020 06:46 PM
@akshay s. The user action degradation is from analysis of the User Session Transactions within your defined applications. Dynatrace uses an Apdex that is defined at the application level for what classifies as excellent, good, satisfied, and frustrated. Dynatrace's AI engine reviews this data and then raises an alert as the issues pass the AI threshold.
Apdex Link: https://www.dynatrace.com/support/help/how-to-use-dynatrace/real-user-monitoring/how-to-use-real-use...
let me know if you need any other assistance
