How can I monitor 2 factor authentication login?
ossenberg
Newcomer
Is it possible with the onbaord tools to monitor a 2 factor authentication login page? The problem might be the simulation of the SMS code generator. I thought about it to send a SMS to Mail and afterwards read out the IMAP code, to monitor the success of a hidden backround job. After this I want to have a real time dashboard not a standard report. ...any ideas?...Many thanks to the community and developers.
ChadTurner
Leader
@Sven O. were you able to get monitoring set up for this? If so how did you do it? did you run into any issues?
-Chad
