How to monitor the queue depth
pbijgavne
Newcomer
I'm just looking for help how can i monitor my queue depth using one agent. I tried to search but couldn't get any info. I want to monitor the IBM MQ and get the queue depth and wanted to put the threshold to trigger an email. Any solution would great help on this. Thank you.
4 REPLIES 4
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
The easiest is to use an extension. We use it internally in Dynatrace as well. See a sample screenshot:
More info here: https://www.dynatrace.com/support/help/technology-support/dynatrace-extensions/dynatrace-extension-r...
Senior Product Manager,
Dynatrace Managed expert
Malaik
DynaMight Champion
DynaMight Champion
HI @pbijgavne
IBM MQ is available through the extension
Once the extension deployed, and configured, you will be able to retrieve all the metrics.
Sharing Knowledge
moramramesh
Newcomer
How can I monitor CPU queue using Dynatrace Managed?
I tried searching with keywords like queue/depth in custom graph metrics but couldn't get any result.
I wanted to check if any threads are waiting for CPU during performance testing.
hi @moramramesh  - look above - the same extension solves your problem.
