Log monitor does not work well in DynaTraceSaaS environment
ykamisa1
Participant
My name is Hirata.
Currently, under the DynaTraceSaaS environment, the target server (One Agent)
In order to perform log monitoring, I set the setting,
I will not succeed.
Can you advise on the cause?
The situation is described below.
1. "Setttings" - "Log Analytics" - from "Events"
I added the following log monitoring.
EventName: TEST
Search for pattern using: * error *
Generate: Log Error Problem
If number of occurrences is lower than 1 / min
Selected log files: Windows Operating System (Windows Application Log Windows Security Log Windows System Log)
2. Output test message with eventcreate command
3. In 'Pattern occurrences in last 24 hours'
Alert output on the graph has been successfully detected
4. Alerts are not output to "Problems"
I registered in "Problem notification setup"
Mail notification is not made to the mail address
Thank you.
3 REPLIES 3
sebastien_aigue
Newcomer
Hello. My name is Sebastien and I have exactly the same problem !
Thank you
sebastian_kryst
DynaMight Leader
DynaMight Leader
Hello Hirata,
one question at start, I understand that you have proper log analytics quote in your license?
edyta_kalka
Inactive
Hi, Please check if problem exists with prod agent versions:
1.157.258.20190115 or 1.159.207.20190110.
