Need a integration part of payload(SAAS) for sccd ticketing tool
sarathkumar_ram
Newcomer
When a Dynatrace monitor detects a situation above a set threshold (i.e. CPU utilization high), it will generate an alert and create a ticket in ticketing tool, Here's an example of a ticket created as part of testing. Note the word "OPEN" under the details, noting that an alert has been triggered. When a Dynatrace monitor detects that the threshold value is no longer being exceeded (i.e. CPU utilization had now dropped back down to acceptable levels after a job completes), the "alert" will be "cleared" on the Dynatrace console to show that the issue is resolved. Ideally, the existing SCCD ticket will be updated to indicate that the issue is resolved. That's often handled by other systems creating a worklog entry for the existing ticket. However, what's happening with Dynatrace right now is that a completely new ticket is being created, with the word RESOLVED in the details. This means for each issue, two tickets are being created. One when the "alert" is opened in Dynatrace and one when the alert is resolved in Dynatrace.
6 REPLIES 6
JamesKitson
Dynatrace Guru
Dynatrace Guru
franz_soengen
Inactive
Hi Sarathkumar,
am I correct in assuming you are using the Custom Webhook Integration feature? The second request sent by Dynatrace is exactly what you are describing as "clearing" the problem. Dynatrace identified the problem to be over and sends another request with State=Resolved. You won't have to close these tickets manually.
If you just get another ticket when the State=Resolved request comes in, it seems that the second request isn't mapped to your ticket created by the first request. You could use the {PID} placeholder as an identifier to accomplish this.
If your ticketing system doesn't support such behavior, you'll need to write a small middleware to map these two requests to your ticket.
best regards
Franz
sarathkumar_ram
Newcomer
"PROBLEMID":"{PROBLEMID}"
"Ownergroup":"ABCR-C-WIZMWAR",
"PLUSPCUSTOMER":"abc",
"REPORTEDBY":"abc.COM",
"IMPACT":"3",
"URGENCY":"3",
"CLASSIFICATIONID":"APPLICATION RATESHOP",
"SITEID":"ABCR",
"EXTERNALSYSTEM":"EVENTMANAGEMENT",
"DESCRIPTION":"{ProblemTitle}",
"DESCRIPTION_LONGDESCRIPTION": "{ProblemDetailsHTML}",
"PID":"{PID}"
Currently we are using above script, it already has PID in it. It still generates separate ticket for RESOLVED event.Please help me with modified script
Hi Sarathkumar,
I'm not familar with SCCD but you'll have to use this PID to map the request to an existing ticket, if available. This will have to be done inside the tool. Dynatrace is only able to send these static requests on Problem occurrence and resolution.
If the tool doesn't support this you'll have to write a middleware as said in James' post and mine above.
best regards
Franz
Your ticketing tool would need to be what handles this - it has no way of knowing that the PID is an identifier for problems or what other information says when it is an update to an already opened problem. This needs to be configured on the ticketing tool side if it is supported by your tool. Otherwise you'd need to find an alternative such as the middleware Franz described.
sarathkumar_ra1
Newcomer
Guys give me idea to create middleware
