Dear DT experts
In managed dynatrace for hosts, i am unable to set customer alert for high RAM usage with respective to the "Process Groups"
Attached screen shot.
In the screen shot you can see, that i am unable to select Memory/RAM, infact no metrics are being populated. Especially for Process Group.
Thank You.,
Siraj.
Regards, Siraj.
Hi Siraj,
Unfortunately RAM usage for a process/ProcessGroup is not a metric available for custom alerts at this time. For the issue of not seeing any metrics at all, this seems to be a bug. A quick workaround is to select "Process" instead of Process Group, you will see a drop down below asking to "select a process group". Select "All instances", you should then see a list of metrics available for custom alerting and they will apply to all processes in the Process Group. You can create a support ticket for the bug also.
Hope this Helps
NJ
Hello NJ,
Thank You for your response.
But, the RAM/Memory usage metric is not available with this work around. 😞
BR, Siraj.
Hi Siraj, as it is hard to troubleshoot this without taking a look at your environment, let´s discuss this on our side. Best regards,
Silvia Moreno
