Problem Notification Customization
Malaik
Organizer
Hello All,
If there any possibility to customize more the email sent in the notification problem.
see the screen bellow,
If there any possibility to extract some informations before sending the notification ...
I need this information to send with the email notification a link that include Dashboard for the impacted Service/Method...
Thanks for your help.
Sharing Knowledge
ChadTurner
Guru
outside of email integration you can edit the payload of the alert But even that is limited. Event with a custom payload, you would only be able to pass a static dashboard link.
I recommend putting in a RFE for this.
-Chad
ct_27
Helper
I wrote up an RFE but may have to go back and simplify it.  Would my RFE support what you're looking to do?
https://community.dynatrace.com/t5/Dynatrace-product-ideas/RFE-Problem-Notification-Placeholder-Add-...
