Alerting
Generate Problem notification report using DQL
Is there a way to generate list of problem notifications using DQL?
Srikanth S
4 REPLIES 4
p_devulapalli
Leader
@SrikanthSamraj When you say "problem notifications", are you referring to list of active/close problems  or list problems that were notified as email or sms etc., ?
Phani Devulapalli
@p_devulapalli - I'm not referring to problems here instead the list of notifications created in settings -> integrations -> problem notifications.
@SrikanthSamraj Not sure you would be able to query the problem notifications using DQL, however you should be able to extract the details via API if it helps.
https://docs.dynatrace.com/docs/discover-dynatrace/references/dynatrace-api/environment-api/settings...
Phani Devulapalli
Thanks @p_devulapalli . I'm aware of the API part, curious to figure out if the same can be achieved via DQL.
