Starting Notifications with errors
jose-antonio_ra
Inactive
Hi all.
How can I make emails alerted by Failure rate only be sent if the problem has been open for more than 10 minutes?
I have changed this configuration
but I still receive the email Subject: OPEN Problem that takes less than 10 minutes.
Is there anything this is doing wrong?
Thanks in advanced.
Jose A
3 REPLIES 3
The question is what alerting profile is configured in Problem notification integration. The one that you've changed or not? 🙂 Maybe you have multiple integrations with different alerting profile which overlap somehow?
thanks Sabstian
I only have 2 alerted profiles, and 2 alerting channel.
I don't think my problem goes there; I'm sure I'm adjusting 😜
I was asking before on my environment it was working fine (at least some times ago when it was configured).
