20 Dec 2019 06:00 AM
We have azure account integrated with dynatrace and we can see azure metrics available for charting and alerting however no timeseriesId available for these metrics. I called the api endpoint https://dynatrace-managed.com/e/xxxxxxxxxxxxxxxxxxxx/api/v1/timeseries?api-token=xxxxxxxxxx from my environment but could not find azure metrics.
Do we have timeseriesId defined for metrics reported in Dynatrace through azure integration?
Suresh
14 Jan 2020 09:31 AM
You just have to use on Metrics explorer from TimeSeries V1 to TimeSeries V2 and you will find what you need 🙂
