Understanding Slow Disk Problems
matthew_gardner
Dynatrace Helper
Dynatrace Helper
Hello Everyone,
I am trying to understand what might be causing some slow disk problems on a monitored host. We can see that latency shoots up in intervals of 5 minutes, and sometimes reaches 300ms+
Just before that, we can see the throughput go up, but not a ton of data is being written:
From the IOPS metrics, we can see after writes/s go up, so does the queue length:
3 REPLIES 3
ChadTurner
The host in question, is it a SQL host? Are there any commits taking place that might cause the latency?
-Chad
The server uses InterSystems IRIS technology. Which is a database technology, so that could be part of the problem since we see latency go up after some writes.
AntonioSousa
There are a lot of cases where you might see a slow disk problem. Some I have encountered:
  • You have a slow HDD disk, with a slow RPM. This doesn't seem to be your case.
  • You are using logic volumes, or in some way, the disk is virtualized. Another system is using it extensively, so you're getting high latency in your case.
  • You have a filesystem that is clogged. It might be due having a lot of files in a directory, it is heavily fragmented, etc.
  • You have a disk with problems. Check the SMART of your disks.
These are some I remember fast. On the funny side, I haven't experienced the following type of proble, at least that I know of:
https://www.youtube.com/watch?v=tDacjrSCeq4
Antonio Sousa
