Why thresholds are not coming in Dynatrace Problems?
muthukumar_peri
Advisor
Hi All,
Whenever I receive problem notification in Dynatrace, I'm not able to see the threshold in problem details. For example, I have kept alert for Disk usage, if it goes over 80%, I'm receiving problem as "Low Disk Space" but it's not giving the current value of the disk space.
Did anyone faced similar issue and had any solution to fix this?
Regards
Muthu
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
I expect that you are running a Dynatrace Managed deployment as this was already fixed in one of the last releases. So if you receive your Dynatrace Managed update you will also have the more detailed message as it is shown below. Same is true for ELB related event messages. I hope that answers your question?
Thanks, Wolfgang.
Yes, I'm using Dynatrace Managed. Do you know on which release version has got that fix please?
Regards
Muthu
