integration ->problem notification -> email integration-> add custom placeholders
ravikant_maurya
Inactive
Hi Team,
Can we have custom placeholders in integration section while integrating a problem notification with other notification systems i.e email integration.
Example : Adding a custom placeholder for customized URL that can be added to the subject.
It can be a good feature if we can add custom placeholders. @kavya hiremath @jarett
Ravikant Maurya
wolfgang_beer
Dynatrace Champion
Dynatrace Champion
Dear Ravikant,
Can you please explain a bit what you would like to do with that placeholder? As we are filling the placeholders on the fly, where should we take the value of the placeholder in that case?
Best greetings,
Wolfgang
I would like the ability to put a property from a custom plugin into the problem notification. We have a custom plugin that looks at JMX properties, and I would like to be able to put those properties into the Notification, for quicker alerting without having to drill down into the problem. @Wolfgang B.
