6.5 to 7.2 Collector Migration issue
jfrazee
Contributor
We’re getting this error during Collector migration:
The option targetDTHome doesn't define a Dynatrace Server or Collector install directory.
Here’s the command we’re trying to run:
java -jar dynatrace-migration.jar -migration -sourceArchive /home/dynatrace/dynatrace-6.5-archive/*.dtma -targetDTHome /home/dynatrace/dynatrace-7.2
We had run this migration command for 7.1 and it worked in both server and collector.
This also works in the server for 7.2, but not collector.
Here is the page we used for documentation, it makes no mention of any difference for server vs collector:
https://www.dynatrace.com/support/doc/appmon/installation/upgrade-and-migration-guide/upgrade-server...
jfrazee
Contributor
Got this working by using 7.2.0.1583 build instead of the latest 7.2.0.1697
thomasK
Dynatrace Pro
Dynatrace Pro
The very likely root cause was JLT-226431, a unix-installer issue.
We provided an updated installer version on the 7.2 download page.
If anyone else runs into this, please stick with 7.2.0.1697 and otherwise open a support ticket.
Best regards,
Thomas
