7.2 collector won't load ojdbc.jar in plug-in libs
matthew_pomery
Newcomer
We have an issue with community plugins (ex. DB Query Monitor ) that use the ojdbc(5,6).jar files. When the collector starts we receive the message "Is ignored" for these .jars in the Collector_OSGI.log file. This causes the plug-ins to throw a class not found exception when attempting to connect to Oracle databases.
Has anyone run into this?
!ENTRY Bootstrap 1 0 2020-01-24 08:50:15.620
!MESSAGE entered Collector bootstrap
!ENTRY Bootstrap 1 0 2020-01-24 08:50:15.886
!MESSAGE Successfully loaded fixpack '7.2.19.1064' located in 'D:\Dynatrace\Dynatrace Collector 7.2\collector\instances\collint_s0229_agents_dev\updates\update_7.2.19.1064' - originally installed dT version was '7.2.0.1697'
!MESSAGE Dynatrace Collector starting up...
!ENTRY Bootstrap 1 0 2020-01-24 08:50:22.125
!MESSAGE Oracle JDBC driver file 'D:\Dynatrace\Dynatrace Collector 7.2\collector\instances\collint_s0229_agents_dev\conf\plugins\com.db.tabmon_3.2.4\lib\ojdbc5.jar' is ignored
!ENTRY Bootstrap 1 0 2020-01-24 08:50:22.156
!MESSAGE Oracle JDBC driver file 'D:\Dynatrace\Dynatrace Collector 7.2\collector\instances\collint_s0229_agents_dev\conf\plugins\com.logfile_3.15.7\lib\ojdbc6.jar' is ignored
0 REPLIES 0
