Ability to set a filter on PurePath TOP Findings column and save as dashboard.
ajit_kunjir1
Inactive
Hi Team,
I would like to create dashboard to find out N+1 Query
problem in PurePath. I could see it under Top Findings column but unable to set
filter on it. Is it possible to set filter on it and save as dashboard?
Any help on this greatly appreciated.
Thank You
Radu
Dynatrace Pro
Dynatrace Pro
Hi Ajit,
It's not possible to set a filter to a dashlet or dashboard based on the Top Findings problem pattern.
However, if you search (CTRL + F) in the PurePaths dashlet, it will refine results based on problem pattern as it searches in all text present in that dashlet. This may not be 100% accurate though, as for example "Response Time: very slow" also shows very fast purepaths.
My advice would be to use the web client for performing this task, and, if needed, send the PurePath to the desktop client (using the "Open in client" button).
Radu
JamesKitson
Dynatrace Leader
Dynatrace Leader
Yep, here's an existing RFE you can vote for and comment on if interested:
https://answers.dynatrace.com/spaces/151/product-feedback-and-enhancement-requests/idea/168052/rfe-top-findings-problem-patterns-as-bt-split-filt.html
