Analyze first method occurrence in Measure is processing later method references
vmotupalli
Newcomer
In the purepath where this measure is defined, there is sendRequest method invoked more than once.
I wanted measure to fetch value based on return value from first occurrence only. Hence opted option to only analyze first method occurrence as shown in attached screenshot.
There is regex condition for Measure as shown in screenshot. When the regex pattern fails for method first occurrence it is considering the second method invocation also. I do not want that behavior. If condition matches measure to extract required value and if it doesn't then ignore but not to consider return value from second occurrence of the same method. Please advise
0 REPLIES 0
