AppMon Regex: Is there way to force dot to match newlines too?
Hello there, In appmon, Is there way to force in dynatrace to match newlines too for the . meta char? Here is a use case.
Hi Rajesh,
you should be able to prefix your regex with
(?s)
in order to match newlines with the dots. Let me know if it worked, thanks,
Peter
Great ! Thanks a lot Peter! Was Not aware of that flag !
