AppMon and TIBCO BW+EMS Best Practices
patrick_cuff
Newcomer
Environment:
  • AppMon 6.1.0.7880
  • TIBCO Business Works (BW) 6.3.5
  • TIBCO Enterprise Message Service (EMS) 8.3.0
  • Red Hat Enterprise Linux 7.3
We're trying to configure Dynatrace with our TIBCO environment and have some questions:
  1. What BW .TRA file(s) do we need to edit with the java.extended.properties? We were successful integrating Dynatrace with BW when we edited the AppNode .TRA file, but since we have 10 AppNodes, we consumed 10 licenses. Is there a way to inject the agent higher up on the BW "food chain" so that we cover all the AppNodes and Applications, but use fewer licenses?
  2. We have the BW and EMS community plug-ins installed, but the EMS plug-in doesn't seem to be getting any info. Is there something we need to configure on the EMS server so Dynatrace can get data from it?
Thanks 🙂
4 REPLIES 4
tarun_agastya1
Inactive
Hi Patrick,
Did you provided all the details for the EMS monitoring plugin and scheduled with collector.I am able to see data.ems.png
Thanks Tarun; turned out to be an issue within our environment. The Dynatrace plugin was trying to access the server by machine name, but that name was unreachable on our network (couldn't ping it). We had our Dynatrace admin add a new host using the fully qualified name and everything's working now.
tarun_agastya1
Inactive
Hi Patrick,
Have you setup dynatrace for Tibco ASG(Active ServiceMatrix Gateway) and Tibco PolicyDirector.If so can you guide me how can we setup.
patrick_cuff
Newcomer
Sorry, we don't have those Tibco products, just BW and EMS.
