Appmon agent for node.js not starting up
himanshu_mor
Advisor
HI Team,
my appmon agent is not stating up for node.js and i can see below error logs:
2019-03-14 07:29:06.349 UTC [586a780f] info [nodejs] Platform .................... linux
2019-03-14 07:29:06.349 UTC [586a780f] info [nodejs] Arch ........................ x64
2019-03-14 07:29:06.349 UTC [586a780f] info [nodejs] Node version ................ v6.12.3
2019-03-14 07:29:06.349 UTC [586a780f] info [nodejs] Agent version ............... 1.123.253.20170911-155635
2019-03-14 07:29:06.349 UTC [586a780f] info [nodejs] Script ...................... ProcessContainerFork.js
2019-03-14 07:29:06.349 UTC [586a780f] info [nodejs] AppName ..................... ********
2019-03-14 07:29:06.349 UTC [586a780f] info [nodejs] Blacklisted ................. false
2019-03-14 07:29:06.349 UTC [586a780f] info [nodejs] MainModule .................. /var/node/base/app.js
2019-03-14 07:29:06.349 UTC [586a780f] info [nodejs] require.main................. /var/node/base/app.js
2019-03-14 07:29:06.350 UTC [586a780f] info [nodejs] uncaughtException listeners installed: 1
2019-03-14 07:29:06.350 UTC [586a780f] info [nodejs] original listener <g> has already a listener attached: uncaughtListener
2019-03-14 07:29:06.352 UTC [586a780f] info [nodejs] Agent options: { server: '***********************************************:8043', agentName: '**************' }
2019-03-14 07:29:06.352 UTC [586a780f] info [nodejs] Starting application: *******************
2019-03-14 07:29:07.873 UTC [586a780f] info [nodejs] new uncaught exception listener:
2019-03-14 07:29:07.895 UTC [586a780f] warning [native] Unable to get resource name for randomBytes
2019-03-14 07:29:13.413 UTC [586a780f] warning [native] session cookie "**************************************************************"is too big; ignoring it
2019-03-14 07:29:16.734 UTC [3bff888f] warning [native] ... last message repeated 5 times ...
2019-03-14 07:29:16.734 UTC [3bff888f] info [native] ============================== Agent inactivated ============================== (no more data will be sent by this agent, except heartbeats and config requests.)
2019-03-14 07:29:16.734 UTC [3bff888f] info [native] Agent configuration updated; agent is now inactive
Looking for troublehsooting help here.
HImanshu Mor
henk_stobbe
Mentor
Hello HImanshu,
Did you have any feedback on this?
KR Henk
