Auto changing of Timeframe of dashboard not working proper in AppMon 7.1
satish_more1
Participant
I am using AppMon 7.1. I have scheduled a report of dashboard keeping timeframe as yesterday. Schedule is at 5:30 AM. So my problem is suppose today is Saturday and I schedule this task today.so when it run on Sunday morning at 5:30 AM, I should get report of YESTERDAY i.e Saturday. But it gives report of last Friday because when it was schedule that time YESTERDAY was friday. Timeframe should change automatically but it is not changing.
Please help.
Thanks and Regards
Satish More
4 REPLIES 4
satish_more1
Participant
Am I posted this in wrong window. Please help me out .
shane_korbel
Dynatrace Pro
Dynatrace Pro
The timeframe will be whatever is selected in the dashboard. It sounds like you either want to use "yesterday" as a timeframe or if you don't want midnight to midnight you will have to use "last x" then select the timeframe, then shift it by however many hours back it needs to be so that you get the correct timeframe you want for yesterday.
satish_more1
Participant
I want to use "yesterday" as a timeframe.
Hello @Satish M.
You can use the interval as last 24 hours or last X with the 24 hours shifted by 1 days.
Babar
