Baseline alerting for low traffic transaction
We have several critical business transactions in place and I'd like to get alerted if it deviates from the baseline. Well, I thought that it would be easy to accomplish, but these critical transactions do not have a high throughput... Only a few requests per minute, but are considered important for the business
The thing is that it never reach the 'significant measure' status, so we never get alerted for these BTs!
I think that there is a lack of flexibility regarding baseline monitoring. I really believe that baseline monitoring is the way to go, but I cannot make it work as desired...
I don't want to waste time setting manual threshold, I think that this is not the best way to go. The system should have the capability to let me know when a situation becomes abnormal
Did I miss something? Any suggestion?
4 REPLIES 4
Mike_L
Dynatrace Pro
Dynatrace Pro
Baselines work great for high throughput transactions, but low throughput transactions will not be able to use the throughput baselines. The best thing to do is to create fixed thresholds. What is the reason that you don't want to do that?
Mike
Setting individual threshold per transaction is time consuming. Threshold can be too low or too high, who knows? It takes some time to know what the right threshold should be... I don't say that this is not feasible, but I think that in 2016, we should have the ability to leave the system learn what a normal behaviour is and get notified when it becomes abnormal
andreas_grabner
Dynatrace Leader
Dynatrace Leader
Unfortunately AppMon doesnt provide automatic baseline on throughput - at least not alerting. We do calculated an "expected" throughput funnel if you put the BT on the Monitoring Dashboard - but we are not alerting on it as we do for Response Time or failure rate. It is a missing capability that we are aware of and that we are trying to address in upcoming releases
Andi
Automatic baseline on throughput would be great, but having the possibility to generate response time or failure rate incidents for low traffic BTs would be great too. The concept of significant measurement is great, but doesn't allow enough flexibility to monitor critical transactions that do not have a high throughput. Hopefully there gonna be improvements for that too...
See here what a chart looks like.
