CAS Data and Appmon data is not same after drilldown.
deepak_u
Newcomer
Hi Team,
Question 1: The data filtering time stamp is not same from CAS to Appmon. While checking this the option in passing filter is set to "Do not pass anything to the target report by default". I tried to change this option but all the options are disabled. Can some one help me to change this option also to enable them. Question 2: what will be the impact if we change the Default option.
Deepak U
BabarQayyum
Leader
Hello Deepak,
This is mandatory, if the AMD is not managed by a report server, you will have to configure the time synchronization by using NTP client software. The NTP client software is used to restart traffic monitoring when a time continuity problem occurs. NTP client software is installed as part of the operating system and can be configured to start up automatically.
Review the below link for more insight.
https://www.dynatrace.com/support/doc/dcrum/instal...
Babar
deepak_u
Newcomer
Thanks Bharbar for the response.
But now in appmon i get different error. please refer the screenshot below.
Also we don't get any http 4xx error we get only 5xx errors. Kindly let me know what chnages to make.
Deepak U
