Can not load dtagentXXX.js on web page
carlos_chang
Inactive
Hi guys,
I have a IIS web server and a web page deploy on it, now I need to inject dtwsagent.js and monitor user action, but I found that I can't inject to the right path.
For example, the target page is localhost/*/*.aspx, only root folder domain(like localhost/*) can be inject successful, I've set agent location to "./", so I wondering how to config correctly
BabarQayyum
Leader
Hello Carlos,
Make sure that the HTTP headers x-dtPostBody, x-dtHealthCheck and x-dtAgentId do not get blocked in your environment. The UEM Health Check needs them to work properly.
Follow the below link and perform the basic UEM Health Check to know the exact issue and share the result with us.
https://community.dynatrace.com/community/display/...
Babar
