Can someone help me with the dashboard for Monitoring Java Web Services?
In Web Services dashlet we do see some information about the service being triggered like the number of hits to the service,avg, sum response time etc.But doesn't give information about the client that triggered this service.Is it possible to prepare a dashboard that shows number of clients and calls made by each client to a particular service.
BabarQayyum
Leader
Hello Vamshi,
Can you see the C/S (Client/Server) calls on the dashlet or only the S (server side) calls?
If there are C/S calls then right click to open the PurePaths dashlet and add the column of Client IP.
Later on you can configure the custom sensor to capture the specific IP Address and the User ID for the metrics/dashboards/business transactions purposes.
Babar
