Can't figure out difference between two PurePaths
Vaquar_Shaikh
Participant
Hello, Attached screenshot shows purepath, can someone review and provide where is time getting consumed ?
Both sides are serving same webrequests, however where is 1361ms and 895ms used, respectively ?
arihant_polavar
Dynatrace Pro
Dynatrace Pro
Hello Vaquar,
Can you scroll to the right and show us the elapsed time columns in the Purepath tree as well? That might help point us in the right direction.
Ari
Vaquar_Shaikh
Participant
Here is the snapshot showing elapse time, showing "Synchronous Path(HTTP)" taking 1,781ms which is major chunk of time. I also see in other PurePath "Asynchronous Path(ASP.NET)" taking major chunk. Is it due to CLR ? or our code ?
