Can we monitor URL for accessibility/availability ,URL is not reachable / accessible
karthikayini_mu
Inactive
Is it possible that we achieve the same using AppMonDynatrace? We have below requirements:
  1. Monitor the XXX application URL for accessibility/availability
  2. Monthly reports for availability of application in terms of %
  3. Alerting in case the URL is not reachable / accessible (Login)
Thanks & regards
Karthikayini M
BabarQayyum
Leader
Hello Karthikayini,
The URL Monitor provides a convenient and easy way to monitor availability and performance-related data for a specific HTTP URL.
https://www.dynatrace.com/support/doc/appmon/infra...
Babar
Hi @Babar Q.
Thank you for the reply.
Regards
Karthikayini M
