Collector Group Agent Fail Over: Collector -> Server Connection lost
ryan_shaw
Dynatrace Helper
Dynatrace Helper
I was wondering if agents that are connected to a collector which loses connection to the server will they attempt to fail over to a different collector in the group that still has connection?
Babar_Qayyum
Leader
Hello Ryan,
If you have a collectors group then the agents will automatically connect to the HA/FO collector, because once we make collectors group then each connected agents will have a collectors list in the configuration which helps to connect automatically in the case of failed/disconnected of any collector.
Note: PurePaths and measurements of connected Agents and of Collector plugins will be missing for the minute the Agents try to reconnect to the Collector and could´t buffer.
Babar
