Collector load balancing for bootstrap 6.0.0
rajanikanthanka
Inactive
All of our agents are running on 7.0.7 but they still have bootstrap version of 6.0.0. We have collector group , load balancing. Does bootstrap version 6.0.0 support Collector load balancing?
Rajani
Babar_Qayyum
Leader
Hello Rajani,
Agents need to have the same or lower version (eg. 6.5, 7.0, ..) than the Collector. Compatibility is guaranteed for Collectors of supported versions, but typically also true for all Agent versions greater than 5.6.
Review the below link for the component compatibility.
https://www.dynatrace.com/support/doc/appmon/insta...
Babar
