Connected (Issue: Instrumentation was disabled during Agent startup. The Collector runs on low memory.)
ashutosh_singh1
Organizer
Dear Team,
I am facing issues with collector low memory, It is disconnecting agents and showing error collector run on low memory. It happened thrice in a week.Collector runs on sufficient resources with 12GB RAM.
Kindly provide solution for same if anyone have faced above issue.
~Thanks
Ashutosh
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Ashutosh,
12GB RAM is ok but there are many other factors as per the collectors best practices.
https://community.dynatrace.com/community/display/...
Just open the 'Collector Sizing' dashboard and check the status of Memory Usage minimum for the last 7 days.
Babar
martin_chochke1
Advisor
Did you increase the heap size of the collector process? If so you may need to add more collector instances and load balance them to fix this.
