Conversion Rate between reservation steps
ajdimanuel
Inactive
I am handling an Application which has 3 Reservation Steps. The thing is that I need several Conversion Rates, the first one should show the Rate of visits who goes to the second step from the first Step (Step2 Requests / Step 1 Request) *100. The second Conversion rate should show the Rate of visits who goes to the third step from the second Step (Step3 Requests / Step 2 Request) *100.
The last Conversion rate (I got it) shows the global Conversion rate.
Do you know how the get it?
Alberto.
francisco_royo
Dynatrace Supporter
Dynatrace Supporter
Hi Alberto,
you can define a measure for the requests of step 2 and filter them by the request header "referer", that will be the step 1. Then you can use this measure for the conversion goal.
Regards
