Could not start FrontendServer after upgrade from 7.1 to 7.2
fiona_ta
Participant
we completed the migration steps to upgrade from dynatrace AppMon v.7.1 to v.7.2. However, we could not start dtFrontendServer to continue activate DT License. Error as below:
2019-05-28 13:45:32 UTC SEVERE [ServerBundleActivator] dynaTrace Server NOT started successfully: com.dynatrace.diagnostics.server.ServerBundleActivator start:707
java.lang.IllegalStateException: Password Manager could not be initialized! No matching certificate found.
at com.dynatrace.diagnostics.server.BaseServer.initAndMigratePasswordManager(BaseServer.java:808)
at com.dynatrace.diagnostics.server.BaseServer.initialize(BaseServer.java:330)
at com.dynatrace.diagnostics.server.frontend.FrontendServer.start(FrontendServer.java:729)
at com.dynatrace.diagnostics.server.ServerBundleActivator.startFrontendServerBundle(ServerBundleActivator.java:164)
at com.dynatrace.diagnostics.server.ServerBundleActivator.startBundleImpl(ServerBundleActivator.java:140)
at com.dynatrace.diagnostics.server.ServerBundleActivator.startBundle(ServerBundleActivator.java:130)
at com.dynatrace.diagnostics.server.ServerBundleActivator.start(ServerBundleActivator.java:692)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
at com.dynatrace.diagnostics.bootstrap.Bootstrapper.startDtComponent(Bootstrapper.java:85)
at com.dynatrace.diagnostics.bootstrap.Bootstrapper.startBootstrap(Bootstrapper.java:62)
at com.dynatrace.diagnostics.serverbootstrap.ServerBootstrapActivator.start(ServerBootstrapActivator.java:44)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:389)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1131)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
We are running on Linux server. We appreciate any help to resolve the issue.
Thanks and best regards,
Fiona.
Hello, before migration all certificates were valid? I suggest support ticket for this. If this is production set higher severity.
krunal_dave1
Guide
Hi Fiona,
You can try applying self signed certificate by your self and restart all the components(ex: collectors, server), please find attached screen shot for your referenceThanks
Krunal
