DWR (Direct Web Remoting) with UEM?
jose_iglesias
Dynatrace Organizer
Dynatrace Organizer
hi.
I'm facing a POV with dynaTrace and I see in the visits a lot of Orphan Web Requests that are not related with any User Action. Drilling down to purepaths from the web Requests, I see that all of them are DWR requests. Anyone has experience with this JavaScript library? Do you know if i could add an AJAX detection in the UEM profile that improves the detection of this DWR's?
Thanks in advance and best regards
JMI
3 REPLIES 3
andreas_grabner
Dynatrace Leader
Dynatrace Leader
Have you tried to enable Generic XHR detection in the UEM Config Section called "Manage Capture Content"?. This is the typical fallback option for frameworks that use AJAX Calls via XHR but where we do not provide specific out-of-the-box support
satit_auputtinu
Contributor
Hi all,
I experienced the same issue with DWR too. It only shows action "Loading Page /xxx/yyy" even after enable capturing of Basic XHR and Click Handler.
Tried turning on all the options but still didn't help.
Satit
laurent_izac
Dynatrace Helper
Dynatrace Helper
I encountered the same framework with the same results lately (6.5.11).
I could confirm the behaviour, testing the DWR sample app from http://directwebremoting.org/dwr/downloads/index.html
What could be so specific to DWR that would not be captured by our UEM ? ...
