Dashboard for TCP Port Monitor Plugin
matthias_choy1
Newcomer
Is that possible to add decimal places for the "Availability" measure ?
Currently it is showing "1.00", I would like to show "1.000" instead.
gabriel_casella
Dynatrace Pro
Dynatrace Pro
Probably if you generate a report (excel) from that dashboard you will be able to see the other decimals.
The dashboard rounds the metric/measure when showing it.
Let me know,
