Dependence between measure and business transaction
ext_sales_flore
Inactive
I create a business transaction with a measure.
I reuse my measure in a dashbord.
I desactive my business transaction.
When I reopen my dashbord, there is no more data.
It's normal ? My Mesure was desactivated in the same time as my BT ?
Can you confirm ?
Florent
Cody_Kachelski
Dynatrace Helper
Dynatrace Helper
Hi Florent,
It would depend on if the measure was used for the business transaction, such as a filter, result, or split measure, or if you were using a business transaction result measure. If you deactivate a BT, the result measures will stop collecting data. Thanks!
-Cody
