Despite agent naming has no problem, it doesn't group to correct agent group
waikeat_chan
DynaMight Pro
DynaMight Pro
As we can see in this transaction diagram, the agent name is correct, but somehow in group under 'Web Server' (and I don't even where does this come from) instead of the right group Nsure_Web.
What could possibly go wrong?
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Wai,
As per my understanding the instance belongs to the same host/system profile because of 'Transactions' and 'Host' information and also an index [1] mark.
Have a look on the below link for the configuring an Apache node name especially multiple Apache instances on one host.
https://www.dynatrace.com/support/doc/appmon/insta...
One more thing we need to remember that if the mapping agent name set for the start then only a single name can be enough to map the multiple similar instances/processes.
Babar
