Does AppMon have monitoring scheduling capability ?
shikha_yadav
Guide
Due to excessive overhead caused by AppMon UEM installation the requirement for AppMon is to monitor the application every 3 hours for 5mins. Is this configuration possible ?
JamesKitson
Dynatrace Leader
Dynatrace Leader
Especially if you're referring to agent based monitoring the answer is no.
I would really look at resolving an overhead issue first regardless. First how have you identified this overhead, and second do you have any custom configurations such as custom sensors in place? Out of the box instrumentation should have no more than 2-3% overhead in a typical application (the nature of the application does impact this though).
Excessive custom sensors and some advanced sensor group configurations can increase overhead quite a bit if you're not careful.
James
kyle_kowalski
Dynatrace Pro
Dynatrace Pro
If your talking about network overhead with UEM requests turning off bandwidth monitoring can also help reduce the amount of request the JS agent makes.
HTH,
Kyle
