Drill down capability and/or breadcrumbs in custom dashboards
melissa_hubbard
Organizer
We are currently at v6.5.9. Is it possible to create custom dashboards with a click (not a right-click drill-dwon, just a regular old click) to navigate to a new dashboard? All the out-of-the-box dashboards have this capability to allow you to dig deeper and follow a troubleshooting process flow. I want to be able to do that with my custom dashboards.
Hi Melissa,
You can do that a bit with "Linked dashboards" but you would still have to right click and select "show in dashboards":
"To document common navigation paths, single dashlets can be linked with specific dashboards. The links are configured in the Dashboard Links tab of the Dashlet Properties dialog box. Linked dashboards can be opened through the context menu of the dashlet under "Show in Dashboard""
If this isn't what you are looking for then you can always submit a Request for Enhancement below:
https://answers.dynatrace.com/spaces/151/index.htm...
- Jacob P.
