Drill down capability in Web Dashboard
jcamps
Advisor
Hi all,
we're migrating from client dashbords to web dashboards and we want to know if its possible to do one drill down from one web DB to a the pure paths dashlet (maintaining the dashboard filters).
I try to explain the use case: in the client we can have one DB with multiple filters applied (time range, web request, etc...). If we do a drilldown here, the pure paths dashlet opens maintaining the filters of the initial dasbboard.
The question is: how can I do this in the web interface? For now we do this opening the Pure Paths and applying the filters in the Web DB another time...
Regards, Josep Maria
thorsten_roth
Dynatrace Pro
Dynatrace Pro
did you read the following page?
https://www.dynatrace.com/support/doc/appmon/appli...
Best is to utilize the placeholders.
You can also do the following:
https://myserver:9911/index.jsp#pure-paths
or
https://myserver:9911/index.jsp#pure-path-analytic...
You can find the view name in the URL in the browser when you switch views.
I hope this is helpful.
Thorsten
Hi Thorsten,
thanks for your answer but I don't understand. How can I maintain the dashboards filters in the pure paths view?
Regards!
