23 Aug 2016 02:34 AM
From Jenkins when I tried to Test connection between Jenkins & Dynatrace server, observing below error message - Connection with dynaTrace RESTful interface could not be established
Below is the error message observed in Jenkins log :
Connecting to https://localhost:8021/rest/management/dashboard/Transaction%20Flow%20Dashboard using username "admin"
Aug 23, 2016 9:29:56 AM SEVERE org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$ConnectionPool freeConnection
Host connection pool not found, hostConfig=HostConfiguration[host=https://localhost:8021]
Aug 23, 2016 9:29:56 AM WARNING com.dynatrace.jenkins.dashboard.rest.DynaTraceServerRestConnection validateConnection
Some problem connecting to the dynaTrace REST interface, see stack-trace for more information
com.sun.jersey.api.client.ClientHandlerException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at com.sun.jersey.client.apache.DefaultApacheHttpMethodExecutor.executeMethod(DefaultApacheHttpMethodExecutor.java:213)
at com.sun.jersey.client.apache.ApacheHttpClientHandler.handle(ApacheHttpClientHandler.java:175)
at com.sun.jersey.api.client.Client.handle(Client.java:648)
at com.sun.jersey.api.client.WebResource.handle(WebResource.java:680)
at com.sun.jersey.api.client.WebResource.get(WebResource.java:191)
at com.dynatrace.jenkins.dashboard.rest.DynaTraceServerRestConnection.validateConnection(DynaTraceServerRestConnection.java:99)
at com.dynatrace.jenkins.dashboard.TestAutomationRecorder$DescriptorImpl.doTestDynaTraceConnection(TestAutomationRecorder.java:154)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.kohsuke.stapler.Function$InstanceFunction.invoke(Function.java:324)
at org.kohsuke.stapler.Function.bindAndInvoke(Function.java:167)
at org.kohsuke.stapler.Function.bindAndInvokeAndServeResponse(Function.java:100)
at org.kohsuke.stapler.MetaClass$1.doDispatch(MetaClass.java:124)
at org.kohsuke.stapler.NameBasedDispatcher.dispatch(NameBasedDispatcher.java:58)
at org.kohsuke.stapler.Stapler.tryInvoke(Stapler.java:746)
at org.kohsuke.stapler.Stapler.invoke(Stapler.java:876)
at org.kohsuke.stapler.MetaClass$5.doDispatch(MetaClass.java:233)
at org.kohsuke.stapler.Stapler.invoke(Stapler.java:649)
at org.kohsuke.stapler.Stapler.service(Stapler.java:238)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:135)
at hudson.util.PluginServletFilter.doFilter(PluginServletFilter.java:126)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
at hudson.security.csrf.CrumbFilter.doFilter(CrumbFilter.java:80)
at hudson.security.ChainedServletFilter$1.doFilter(ChainedServletFilter.java:84)
at hudson.security.ChainedServletFilter.doFilter(ChainedServletFilter.java:76)
at hudson.security.HudsonFilter.doFilter(HudsonFilter.java:171)
at org.kohsuke.stapler.compression.CompressionFilter.doFilter(CompressionFilter.java:49)
at hudson.util.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:82)
at org.kohsuke.stapler.DiagnosticThreadNameFilter.doFilter(DiagnosticThreadNameFilter.java:30)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:553)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)
at winstone.BoundedExecutorService$1.run(BoundedExecutorService.java:77)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alerts.getSSLException(Unknown Source)
at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source)
at sun.security.ssl.Handshaker.fatalSE(Unknown Source)
at sun.security.ssl.ClientHandshaker.serverCertificate(Unknown Source)
at sun.security.ssl.ClientHandshaker.processMessage(Unknown Source)
at sun.security.ssl.Handshaker.processLoop(Unknown Source)
at sun.security.ssl.Handshaker.process_record(Unknown Source)
at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
at sun.security.ssl.SSLSocketImpl.writeRecord(Unknown Source)
at sun.security.ssl.AppOutputStream.write(Unknown Source)
at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
at java.io.BufferedOutputStream.flush(Unknown Source)
at org.apache.commons.httpclient.HttpConnection.flushRequestOutputStream(HttpConnection.java:828)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.flushRequestOutputStream(MultiThreadedHttpConnectionManager.java:1565)
at org.apache.commons.httpclient.HttpMethodBase.writeRequest(HttpMethodBase.java:2116)
at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1096)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at com.sun.jersey.client.apache.DefaultApacheHttpMethodExecutor.executeMethod(DefaultApacheHttpMethodExecutor.java:210)
... 63 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(Unknown Source)
at sun.security.validator.PKIXValidator.engineValidate(Unknown Source)
at sun.security.validator.Validator.validate(Unknown Source)
at sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source)
... 81 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source)
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source)
at java.security.cert.CertPathBuilder.build(Unknown Source)
... 87 more
23 Aug 2016 03:51 AM
have a look at the section "SSLHandshakeException when trying to connect through HTTPS" of the Jenkins plug-in documentation on Github: https://github.com/Dynatrace/Dynatrace-Jenkins-Plu...
hope that helps,
Sonja
25 Aug 2016 04:19 AM
Hi Sonja,
I have tried all the three options but nothing worked for me . Can you explain in details on below option - either deploy a valid SSL certificate on Dynatrace AppMon server
31 Aug 2016 04:12 AM
Actually the option with http should work in any cases - the solution with a valid SSL certificate is an alternative in case you want to use https and this involves buying a deploying a SSL certificate on your server. See also https://community.dynatrace.com/community/display/...
I would recommend to check first on the http only solution - just to make sure this is really the cause of the issue.
Here are the settings you need to change in Jenkins:
Here are the settings you need to change in AppMon:
Sonja
