Dynatrace Agent connection issue
rsubramanian
Guide
We are using load balancer VIPs for the collector configuration. When we instrument the jvm, we see below error in the collector logs.
2018-02-02 10:49:23 WARNING [AgentListener] Error setting up an agent connection from '(unknown)' at 'x.x.x.x:44760': null
2018-02-02 11:30:39 WARNING [AgentListener] Error setting up an agent connection from '(unknown)' at 'x.x.x.x:64869': null
2018-02-02 12:11:59 WARNING [AgentListener] Error setting up an agent connection from '(unknown)' at 'x.x.x.x:14953': null
2018-02-02 12:53:19 WARNING [AgentListener] Error setting up an agent connection from '(unknown)' at 'x.x.x.x:58707': null
Joe_Hoffman
Dynatrace Champion
Dynatrace Champion
Ram,
The Collector automatically load balances itself, i'm not sure you're solving anything by using a VIP, but perhaps confusing the situation as state likely is getting lost. Do you have the Collectors setup as a Collector Group? If not, then the state information is not shared across the collectors that you VIPed.
