Dynatrace AppMon java agent for websphere running in zOS 2.2
asahoo1
Organizer
We have a vended BPM application - IBM ODM - that is running in zOS 2.2. It is a websphere application. We are using AppMon 7.1.
Can we use the regular AppMon Java agent to monitor the WebSphere vended application running in zOS 2.2? I do see that zOS 2.2 is supported but I can't find any installation / configuration document for WebSphere running in zOS.
Abhaya
asahoo1
Organizer
Any update on the above or do I need to open a support ticket?
