Dynatrace collector not starting after upgrade
tarun_agastya1
Inactive
one of our collector is not starting after upgrade from 6.2 to 6.5.
we are seeing below error message in the logs.can someone help us in resolving this .
2017-03-02 08:27:44 [4c23b880] info [native] Startup jar: /apps/dynatrace-6.5/collector/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
2017-03-02 08:27:44 [4c23b880] info [native] Working directory: /apps/dynatrace-6.5/collector
2017-03-02 08:27:44 [4c23b880] info [native] Configuration file: /apps/dynatrace-6.5/dtcollector.ini
2017-03-02 08:27:44 [4c23b880] info [native] Pid file: /apps/dynatrace-6.5/collector/xx.pid
2017-03-02 08:27:44 [4c23b880] info [native] Native watchdog enabled, port: 50000, timeout: 180 sec (timeout for graceful shutdown: 300 sec)
2017-03-02 08:27:44 [4c23b880] info [native] Process created successfully, pid: 41663
2017-03-02 08:27:46 [4b83e880] info [java ]
2017-03-02 08:30:44 [4c23d880] warning [native] Process 41663 not responding within time limit - still waiting for process to connect...
2017-03-02 08:33:44 [4c23d880] warning [native] Process 41663 not responding, retrieving Java stack trace...
2017-03-02 08:33:44 [4c23d880] warning [native] --- Java stack trace begin --------------------------------------------------------------------------
2017-03-02 08:33:44 [4c23d880] info [native] Signal 3 sent to process 41663
2017-03-02 08:33:44 [4b83e880] info [java ] Full thread dump Java HotSpot(TM) 64-Bit Server VM (25.102-b14 mixed mode):
2017-03-02 08:33:44 [4b83e880] info [java ] "DestroyJavaVM" #23 prio=5 os_prio=0 tid=0x00007f0c0c3e1800 nid=0xa2c2 waiting on condition [0x0000000000000000]
2017-03-02 08:33:44 [4b83e880] info [java ] java.lang.Thread.State: RUNNABLE
2017-03-02 08:33:44 [4b83e880] info [java ] "pool-2-thread-2" #22 prio=5 os_prio=0 tid=0x00007f0bc0676800 nid=0xa2da waiting on condition [0x00007f0bbbbb7000]
2017-03-02 08:33:44 [4b83e880] info [java ] java.lang.Thread.State: WAITING (parking)
2017-03-02 08:33:44 [4b83e880] info [java ] at sun.misc.Unsafe.park(Native Method)
2017-03-02 08:33:44 [4b83e880] info [java ] - parking to wait for <0x00000000895c2188> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.util.concurrent.locks.LockSupport.park(LockSupport.java:175)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2039)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1088)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:809)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1067)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.lang.Thread.run(Thread.java:745)
2017-03-02 08:33:44 [4b83e880] info [java ] "pool-2-thread-1" #21 prio=5 os_prio=0 tid=0x00007f0bc052e800 nid=0xa2d9 waiting on condition [0x00007f0bd870a000]
2017-03-02 08:33:44 [4b83e880] info [java ] at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1081)
2017-03-02 08:33:44 [4b83e880] info [java ] "Worker-0" #20 prio=5 os_prio=0 tid=0x00007f0bc8002000 nid=0xa2d8 in Object.wait() [0x00007f0bd8609000]
2017-03-02 08:33:44 [4b83e880] info [java ] java.lang.Thread.State: TIMED_WAITING (on object monitor)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.lang.Object.wait(Native Method)
2017-03-02 08:33:44 [4b83e880] info [java ] at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.java:188)
2017-03-02 08:33:44 [4b83e880] info [java ] - locked <0x00000000895c23f0> (a org.eclipse.core.internal.jobs.WorkerPool)
2017-03-02 08:33:44 [4b83e880] info [java ] at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPool.java:220)
2017-03-02 08:33:44 [4b83e880] info [java ] at org.eclipse.core.internal.jobs.Worker.run(Worker.java:50)
2017-03-02 08:33:44 [4b83e880] info [java ] "Worker-JM" #18 prio=5 os_prio=0 tid=0x00007f0bc03a9000 nid=0xa2d5 in Object.wait() [0x00007f0bd913e000]
2017-03-02 08:33:44 [4b83e880] info [java ] java.lang.Thread.State: WAITING (on object monitor)
2017-03-02 08:33:44 [4b83e880] info [java ] - waiting on <0x00000000895c2598> (a java.util.ArrayList)
2017-03-02 08:33:44 [4b83e880] info [java ] at org.eclipse.core.internal.jobs.InternalWorker.run(InternalWorker.java:58)
2017-03-02 08:33:44 [4b83e880] info [java ] - locked <0x00000000895c2598> (a java.util.ArrayList)
2017-03-02 08:33:44 [4b83e880] info [java ] "Start Level Event Dispatcher" #14 daemon prio=5 os_prio=0 tid=0x00007f0c0c3a8000 nid=0xa2d2 in Object.wait() [0x00007f0bd923f000]
2017-03-02 08:33:44 [4b83e880] info [java ] at java.lang.Object.wait(Object.java:502)
2017-03-02 08:33:44 [4b83e880] info [java ] at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.getNextEvent(EventManager.java:400)
2017-03-02 08:33:44 [4b83e880] info [java ] - locked <0x00000000895c25b0> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
2017-03-02 08:33:44 [4b83e880] info [java ] at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:336)
2017-03-02 08:33:44 [4b83e880] info [java ] "Framework Event Dispatcher" #13 daemon prio=5 os_prio=0 tid=0x00007f0c0c3b8000 nid=0xa2d1 in Object.wait() [0x00007f0bd9340000]
2017-03-02 08:33:44 [4b83e880] info [java ] - locked <0x00000000899de658> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
2017-03-02 08:33:44 [4b83e880] info [java ] "Framework Active Thread" #10 prio=5 os_prio=0 tid=0x00007f0c0c35a000 nid=0xa2cf in Object.wait() [0x00007f0bd9542000]
2017-03-02 08:33:44 [4b83e880] info [java ] at org.eclipse.osgi.framework.internal.core.Framework.run(Framework.java:1817)
2017-03-02 08:33:44 [4b83e880] info [java ] - locked <0x00000000895dac10> (a org.eclipse.osgi.framework.internal.core.Framework)
2017-03-02 08:33:44 [4b83e880] info [java ] "Service Thread" #8 daemon prio=9 os_prio=0 tid=0x00007f0c0c173800 nid=0xa2cd runnable [0x0000000000000000]
2017-03-02 08:33:44 [4b83e880] info [java ] "C1 CompilerThread1" #7 daemon prio=9 os_prio=0 tid=0x00007f0c0c15e000 nid=0xa2cc waiting on condition [0x0000000000000000]
2017-03-02 08:33:44 [4b83e880] info [java ] "C2 CompilerThread0" #6 daemon prio=9 os_prio=0 tid=0x00007f0c0c15c000 nid=0xa2cb waiting on condition [0x0000000000000000]
2017-03-02 08:33:44 [4b83e880] info [java ] "Signal Dispatcher" #5 daemon prio=9 os_prio=0 tid=0x00007f0c0c15a000 nid=0xa2ca runnable [0x0000000000000000]
2017-03-02 08:33:44 [4b83e880] info [java ] "Surrogate Locker Thread (Concurrent GC)" #4 daemon prio=9 os_prio=0 tid=0x00007f0c0c158800 nid=0xa2c9 waiting on condition [0x0000000000000000]
2017-03-02 08:33:44 [4b83e880] info [java ] "Finalizer" #3 daemon prio=8 os_prio=0 tid=0x00007f0c0c125000 nid=0xa2c8 in Object.wait() [0x00007f0bfc3d5000]
2017-03-02 08:33:44 [4b83e880] info [java ] at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:143)
2017-03-02 08:33:44 [4b83e880] info [java ] - locked <0x00000000899f9e18> (a java.lang.ref.ReferenceQueue$Lock)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:164)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:209)
2017-03-02 08:33:44 [4b83e880] info [java ] "Reference Handler" #2 daemon prio=10 os_prio=0 tid=0x00007f0c0c120800 nid=0xa2c7 in Object.wait() [0x00007f0bfc4d6000]
2017-03-02 08:33:44 [4b83e880] info [java ] at java.lang.ref.Reference.tryHandlePending(Reference.java:191)
2017-03-02 08:33:44 [4b83e880] info [java ] - locked <0x00000000899f9e58> (a java.lang.ref.Reference$Lock)
2017-03-02 08:33:44 [4b83e880] info [java ] at java.lang.ref.Reference$ReferenceHandler.run(Reference.java:153)
2017-03-02 08:33:44 [4b83e880] info [java ] "VM Thread" os_prio=0 tid=0x00007f0c0c119000 nid=0xa2c6 runnable
2017-03-02 08:33:44 [4b83e880] info [java ] "Gang worker#0 (Parallel GC Threads)" os_prio=0 tid=0x00007f0c0c01b800 nid=0xa2c3 runnable
2017-03-02 08:33:44 [4b83e880] info [java ] "Gang worker#1 (Parallel GC Threads)" os_prio=0 tid=0x00007f0c0c01d000 nid=0xa2c4 runnable
2017-03-02 08:33:44 [4b83e880] info [java ] "Concurrent Mark-Sweep GC Thread" os_prio=0 tid=0x00007f0c0c04a800 nid=0xa2c5 runnable
2017-03-02 08:33:44 [4b83e880] info [java ] "VM Periodic Task Thread" os_prio=0 tid=0x00007f0c0c177000 nid=0xa2ce waiting on condition
2017-03-02 08:33:44 [4b83e880] info [java ] JNI global references: 348
2017-03-02 08:33:44 [4b83e880] info [java ] Heap
2017-03-02 08:33:44 [4b83e880] info [java ] par new generation total 153344K, used 126200K [0x0000000080000000, 0x000000008a660000, 0x000000008a660000)
2017-03-02 08:33:44 [4b83e880] info [java ] eden space 136320K, 80% used [0x0000000080000000, 0x0000000086a9e1f0, 0x0000000088520000)
2017-03-02 08:33:44 [4b83e880] info [java ] from space 17024K, 100% used [0x00000000895c0000, 0x000000008a660000, 0x000000008a660000)
2017-03-02 08:33:44 [4b83e880] info [java ] to space 17024K, 0% used [0x0000000088520000, 0x0000000088520000, 0x00000000895c0000)
2017-03-02 08:33:44 [4b83e880] info [java ] concurrent mark-sweep generation total 1926784K, used 5024K [0x000000008a660000, 0x0000000100000000, 0x0000000100000000)
2017-03-02 08:33:44 [4b83e880] info [java ] Metaspace used 21175K, capacity 22356K, committed 22548K, reserved 1069056K
2017-03-02 08:33:44 [4b83e880] info [java ] class space used 2435K, capacity 2775K, committed 2840K, reserved 1048576K
2017-03-02 08:33:54 [4c23d880] warning [native] --- Java stack trace end ----------------------------------------------------------------------------
2017-03-02 08:33:54 [4c23d880] severe [native] Process 41663 not responding within time limit - restarting process...
2017-03-02 08:33:54 [4c23d880] info [native] Signal 15 sent to process 41663
2017-03-02 08:33:54 [4c23b880] info [native] Process 41663 terminated, exitcode: 143 (signal: 15)
2017-03-02 08:33:54 [4c23b880] severe [native] Process was terminated by native watchdog
2017-03-02 08:33:54 [4c23b880] info [native] Restarting Dynatrace Collector...
2017-03-02 08:33:54 [4c23b880] info [native] Launcher configuration summary for Dynatrace Collector:
2017-03-02 08:33:54 [4c23b880] info [native] Launcher: /apps/dynatrace-6.5/dtcollector
2017-03-02 08:33:54 [4c23b880] info [native] Java VM: /apps/dynatrace-6.5/jre/bin/java
2017-03-02 08:33:54 [4c23b880] info [native] Java version: 1.8.0_102 64-Bit
2017-03-02 08:33:54 [4c23b880] info [native] Startup jar: /apps/dynatrace-6.5/collector/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
2017-03-02 08:33:54 [4c23b880] info [native] Working directory: /apps/dynatrace-6.5/collector
2017-03-02 08:33:54 [4c23b880] info [native] Configuration file: /apps/dynatrace-6.5/dtcollector.ini
2017-03-02 08:33:54 [4c23b880] info [native] Pid file: /apps/dynatrace-6.5/collector/dtcollector65_xx.pid
2017-03-02 08:33:54 [4c23b880] info [native] Native watchdog enabled, port: 50000, timeout: 180 sec (timeout for graceful shutdown: 300 sec)
2017-03-02 08:33:54 [4c23b880] info [native] Process created successfully, pid: 41783
2017-03-02 08:33:56 [4ae3f880] info [java ]
2017-03-02 08:36:54 [4c23d880] warning [native] Process 41783 not responding within time limit - still waiting for process to connect...
2017-03-02 08:39:54 [4c23d880] warning [native] Process 41783 not responding, retrieving Java stack trace...
2017-03-02 08:39:54 [4c23d880] warning [native] --- Java stack trace begin --------------------------------------------------------------------------
2017-03-02 08:39:54 [4c23d880] info [native] Signal 3 sent to process 41783
2017-03-02 08:39:54 [4ae3f880] info [java ] Full thread dump Java HotSpot(TM) 64-Bit Server VM (25.102-b14 mixed mode):
2017-03-02 08:39:54 [4ae3f880] info [java ] "pool-2-thread-2" #24 prio=5 os_prio=0 tid=0x00007f90946e5800 nid=0xa352 waiting on condition [0x00007f90b846d000]
2017-03-02 08:39:54 [4ae3f880] info [java ] java.lang.Thread.State: WAITING (parking)
2017-03-02 08:39:54 [4ae3f880] info [java ] at sun.misc.Unsafe.park(Native Method)
2017-03-02 08:39:54 [4ae3f880] info [java ] - parking to wait for <0x00000000895c2188> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.util.concurrent.locks.LockSupport.park(LockSupport.java:175)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2039)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1088)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:809)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1067)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.lang.Thread.run(Thread.java:745)
2017-03-02 08:39:54 [4ae3f880] info [java ] "DestroyJavaVM" #23 prio=5 os_prio=0 tid=0x00007f90ec00a000 nid=0xa33a waiting on condition [0x0000000000000000]
2017-03-02 08:39:54 [4ae3f880] info [java ] java.lang.Thread.State: RUNNABLE
2017-03-02 08:39:54 [4ae3f880] info [java ] "pool-2-thread-1" #22 prio=5 os_prio=0 tid=0x00007f9094537000 nid=0xa351 waiting on condition [0x00007f90b905e000]
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1081)
2017-03-02 08:39:54 [4ae3f880] info [java ] "Worker-1" #21 prio=5 os_prio=0 tid=0x00007f90a8001800 nid=0xa350 in Object.wait() [0x00007f90b8e5c000]
2017-03-02 08:39:54 [4ae3f880] info [java ] java.lang.Thread.State: TIMED_WAITING (on object monitor)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.lang.Object.wait(Native Method)
2017-03-02 08:39:54 [4ae3f880] info [java ] at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.java:188)
2017-03-02 08:39:54 [4ae3f880] info [java ] - locked <0x00000000895c23f0> (a org.eclipse.core.internal.jobs.WorkerPool)
2017-03-02 08:39:54 [4ae3f880] info [java ] at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPool.java:220)
2017-03-02 08:39:54 [4ae3f880] info [java ] at org.eclipse.core.internal.jobs.Worker.run(Worker.java:50)
2017-03-02 08:39:54 [4ae3f880] info [java ] "Worker-0" #20 prio=5 os_prio=0 tid=0x00007f909c003000 nid=0xa34f in Object.wait() [0x00007f90b8f5d000]
2017-03-02 08:39:54 [4ae3f880] info [java ] "Worker-JM" #18 prio=5 os_prio=0 tid=0x00007f909439b000 nid=0xa34d in Object.wait() [0x00007f90b9a6b000]
2017-03-02 08:39:54 [4ae3f880] info [java ] java.lang.Thread.State: WAITING (on object monitor)
2017-03-02 08:39:54 [4ae3f880] info [java ] - waiting on <0x00000000895c2718> (a java.util.ArrayList)
2017-03-02 08:39:54 [4ae3f880] info [java ] at org.eclipse.core.internal.jobs.InternalWorker.run(InternalWorker.java:58)
2017-03-02 08:39:54 [4ae3f880] info [java ] - locked <0x00000000895c2718> (a java.util.ArrayList)
2017-03-02 08:39:54 [4ae3f880] info [java ] "Start Level Event Dispatcher" #14 daemon prio=5 os_prio=0 tid=0x00007f90ec37f000 nid=0xa34a in Object.wait() [0x00007f90b9b6c000]
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.lang.Object.wait(Object.java:502)
2017-03-02 08:39:54 [4ae3f880] info [java ] at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.getNextEvent(EventManager.java:400)
2017-03-02 08:39:54 [4ae3f880] info [java ] - locked <0x00000000895c2730> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
2017-03-02 08:39:54 [4ae3f880] info [java ] at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:336)
2017-03-02 08:39:54 [4ae3f880] info [java ] "Framework Event Dispatcher" #13 daemon prio=5 os_prio=0 tid=0x00007f90ec37d800 nid=0xa349 in Object.wait() [0x00007f90d4196000]
2017-03-02 08:39:54 [4ae3f880] info [java ] - locked <0x00000000897f3700> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
2017-03-02 08:39:54 [4ae3f880] info [java ] "Framework Active Thread" #10 prio=5 os_prio=0 tid=0x00007f90ec376000 nid=0xa347 in Object.wait() [0x00007f90dc1a7000]
2017-03-02 08:39:54 [4ae3f880] info [java ] at org.eclipse.osgi.framework.internal.core.Framework.run(Framework.java:1817)
2017-03-02 08:39:54 [4ae3f880] info [java ] - locked <0x00000000895c0af0> (a org.eclipse.osgi.framework.internal.core.Framework)
2017-03-02 08:39:54 [4ae3f880] info [java ] "Service Thread" #8 daemon prio=9 os_prio=0 tid=0x00007f90ec173000 nid=0xa345 runnable [0x0000000000000000]
2017-03-02 08:39:54 [4ae3f880] info [java ] "C1 CompilerThread1" #7 daemon prio=9 os_prio=0 tid=0x00007f90ec15e000 nid=0xa344 waiting on condition [0x0000000000000000]
2017-03-02 08:39:54 [4ae3f880] info [java ] "C2 CompilerThread0" #6 daemon prio=9 os_prio=0 tid=0x00007f90ec15c000 nid=0xa343 waiting on condition [0x0000000000000000]
2017-03-02 08:39:54 [4ae3f880] info [java ] "Signal Dispatcher" #5 daemon prio=9 os_prio=0 tid=0x00007f90ec15a000 nid=0xa342 waiting on condition [0x0000000000000000]
2017-03-02 08:39:54 [4ae3f880] info [java ] "Surrogate Locker Thread (Concurrent GC)" #4 daemon prio=9 os_prio=0 tid=0x00007f90ec158800 nid=0xa341 waiting on condition [0x0000000000000000]
2017-03-02 08:39:54 [4ae3f880] info [java ] "Finalizer" #3 daemon prio=8 os_prio=0 tid=0x00007f90ec125000 nid=0xa340 in Object.wait() [0x00007f90f01a6000]
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:143)
2017-03-02 08:39:54 [4ae3f880] info [java ] - locked <0x0000000089dbf0d0> (a java.lang.ref.ReferenceQueue$Lock)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:164)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:209)
2017-03-02 08:39:54 [4ae3f880] info [java ] "Reference Handler" #2 daemon prio=10 os_prio=0 tid=0x00007f90ec120800 nid=0xa33f in Object.wait() [0x00007f90dccd6000]
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.lang.ref.Reference.tryHandlePending(Reference.java:191)
2017-03-02 08:39:54 [4ae3f880] info [java ] - locked <0x0000000089cdb458> (a java.lang.ref.Reference$Lock)
2017-03-02 08:39:54 [4ae3f880] info [java ] at java.lang.ref.Reference$ReferenceHandler.run(Reference.java:153)
2017-03-02 08:39:54 [4ae3f880] info [java ] "VM Thread" os_prio=0 tid=0x00007f90ec119000 nid=0xa33e runnable
2017-03-02 08:39:54 [4ae3f880] info [java ] "Gang worker#0 (Parallel GC Threads)" os_prio=0 tid=0x00007f90ec01b800 nid=0xa33b runnable
2017-03-02 08:39:54 [4ae3f880] info [java ] "Gang worker#1 (Parallel GC Threads)" os_prio=0 tid=0x00007f90ec01d000 nid=0xa33c runnable
2017-03-02 08:39:54 [4ae3f880] info [java ] "Concurrent Mark-Sweep GC Thread" os_prio=0 tid=0x00007f90ec04a800 nid=0xa33d runnable
2017-03-02 08:39:54 [4ae3f880] info [java ] "VM Periodic Task Thread" os_prio=0 tid=0x00007f90ec187000 nid=0xa346 waiting on condition
2017-03-02 08:39:54 [4ae3f880] info [java ] JNI global references: 377
2017-03-02 08:39:54 [4ae3f880] info [java ] Heap
2017-03-02 08:39:54 [4ae3f880] info [java ] par new generation total 153344K, used 132050K [0x0000000080000000, 0x000000008a660000, 0x000000008a660000)
2017-03-02 08:39:54 [4ae3f880] info [java ] eden space 136320K, 84% used [0x0000000080000000, 0x00000000870548d8, 0x0000000088520000)
2017-03-02 08:39:54 [4ae3f880] info [java ] from space 17024K, 99% used [0x00000000895c0000, 0x000000008a65fff8, 0x000000008a660000)
2017-03-02 08:39:54 [4ae3f880] info [java ] to space 17024K, 0% used [0x0000000088520000, 0x0000000088520000, 0x00000000895c0000)
2017-03-02 08:39:54 [4ae3f880] info [java ] concurrent mark-sweep generation total 1926784K, used 2929K [0x000000008a660000, 0x0000000100000000, 0x0000000100000000)
2017-03-02 08:39:54 [4ae3f880] info [java ] Metaspace used 21085K, capacity 22228K, committed 22548K, reserved 1069056K
2017-03-02 08:39:54 [4ae3f880] info [java ] class space used 2436K, capacity 2775K, committed 2840K, reserved 1048576K
2017-03-02 08:40:04 [4c23d880] warning [native] --- Java stack trace end ----------------------------------------------------------------------------
2017-03-02 08:40:04 [4c23d880] severe [native] Process 41783 not responding within time limit - restarting process...
2017-03-02 08:40:04 [4c23d880] info [native] Signal 15 sent to process 41783
2017-03-02 08:40:04 [4c23b880] info [native] Process 41783 terminated, exitcode: 143 (signal: 15)
2017-03-02 08:40:04 [4c23b880] severe [native] Process was terminated by native watchdog
2017-03-02 08:40:04 [4c23b880] info [native] Restarting Dynatrace Collector...
2017-03-02 08:40:05 [4c23b880] info [native] Launcher configuration summary for Dynatrace Collector:
2017-03-02 08:40:05 [4c23b880] info [native] Launcher: /apps/dynatrace-6.5/dtcollector
2017-03-02 08:40:05 [4c23b880] info [native] Java VM: /apps/dynatrace-6.5/jre/bin/java
2017-03-02 08:40:05 [4c23b880] info [native] Java version: 1.8.0_102 64-Bit
2017-03-02 08:40:05 [4c23b880] info [native] Startup jar: /apps/dynatrace-6.5/collector/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
2017-03-02 08:40:05 [4c23b880] info [native] Working directory: /apps/dynatrace-6.5/collector
2017-03-02 08:40:05 [4c23b880] info [native] Configuration file: /apps/dynatrace-6.5/dtcollector.ini
2017-03-02 08:40:05 [4c23b880] info [native] Pid file: /apps/dynatrace-6.5/collector/dtcollector65_xx.pid
2017-03-02 08:40:05 [4c23b880] info [native] Native watchdog enabled, port: 50000, timeout: 180 sec (timeout for graceful shutdown: 300 sec)
2017-03-02 08:40:05 [4c23b880] info [native] Process created successfully, pid: 41880
2017-03-02 08:40:06 [4b83e880] info [java ]
Hi Tarun,
I think this might be better suited for a support ticket. You can put in a ticket with Dynatrace Support here.
Hope this helps,
Dan
tthat
Inactive
@Tarun A. check the collector.ini file see there are parameters or not.
