Dynatrace is capturing each application twice, once in upper case and once in lower case. EX: BillingPage versus billingpage
gauthier_gayle
Newcomer
Babar_Qayyum
Leader
Hello Gayle,
Are you detecting application automatically on the basis of Host or Web Application ID or Web Application ID or Host? There some limitations on auto-detected applications.
Check the following link to know the difference between Auto-Detected vs. User-Defined Logical Apps.
https://community.dynatrace.com/community/display/...
Babar
