Dynatrace silent installation for agent
I was making preparations to install the Dynatrace Agent on
the servers. I was going to do the silent installation but went through
the GUI to see the options. The last screen was this: dynatraceagentinstall.jpg I certainly don’t want this enabled with the silent
installation. How do we know it won’t automatically?
gaurav_kodmalwa
Participant
well if you have unchecked it then it wont enable it. Otherwise, after your installation go to "agents overview" tab on Dynatrace client. It will show all the agents and you can control from there as well.
