Easy Travel Application for Mac
nitin_usit
Newcomer
It seems like that there is no mac version available for the Easy Travel Demo Application. Please suggest if there is any alternate available - any alternate demo application that can be used/installed on mac to learn Dynatrace.
3 REPLIES 3
Mike_L
Dynatrace Pro
Dynatrace Pro
Hi Nitin,
Seeing as you don't only need an application but preferably also some problem patterns and several different tiers and a load generator I'd not suggest to install a random application to learn Dynatrace AppMon.
I would suggest setting up a virtualbox with a Linux environment, install easyTravel there and use that as your playground. Please see here for instructions:
https://www.engadget.com/2009/09/07/how-to-set-up-...
http://www.simplehelp.net/2015/06/09/how-to-instal...
Or follow one of the other links here if you want another guide:
https://www.google.co.uk/search?q=mac+install+ubun...
Good luck!
Mike
Joe_Hoffman
Dynatrace Champion
Dynatrace Champion
Nitin,
I use a Mac, but choose to run EasyTravel on a Windows VM. This allows me to showcase the full functionality of EasyTravel, including the .NET components. This makes for a much richer showcase including cross technology transactions.
Joe Hoffman
nitin_usit
Newcomer
Thanks Mike and Joe for the suggestions. Seems like Windows or Linux VM is the way forward. I'll give it a try.
